Power Consumption (Idle and Gaming)
Putting a realistic, repeatable load on a GPU to get a decent idea of its real world power consumption and thermal output has long been something with which we've experimented here at
bit-tech. We've found that synthetic benchmarks such as FurMark thrash the GPU constantly, which simply isn't reflective of how a GPU will be used when gaming.
It's such a hardcore test that any GPU under test is almost guaranteed to hit its thermal limit; the mark at which the card's firmware will kick in, speeding up the fan to keep the GPU within safe temperature limits. Conversely, simply leaving a game such as Crysis running at a certain point also isn't reflective of real-world use. There's no guarantee that the GPU is being pushed as hard as other titles might push it, and the load will vary between play-throughs.
We used to use the Canyon Flight test of 3DMark 06, as this was a punishing and repeatable test. However, we've now adopted
Unigine's Heaven 2.5 benchmark, as its DirectX 11 features will stress all the parts of a modern GPU. We use the default settings and a resolution of 1,920 x 1,080. We also check that 4x AA and 4x AF are enabled and that tessellation is set to Standard. We then hit the Benchmark button and watch the power draw from the wall between the grass field scene and the second dragon scene - this is the toughest portion of the test for both Nvidia and AMD hardware.
We also have GPU-Z running in the background, and leave the Unigine benchmark running for ten minutes to record a peak GPU temperature. We present the temperature as a delta T (the difference between the temperature of the GPU and the ambient temperature in our labs).
AMD Radeon HD 5770 1GB
AMD Radeon HD 6870 1GB
AMD Radeon HD 6950 1GB
Zotac GeForce GTX 560 1GB AMP!
Nvidia GeForce GTX 460 768MB
KFA² GeForce GTX 560 EX OC 1GB
KFA2 MDT X5 GTX 560 Ti 1GB
AMD Radeon HD 5850 1GB
Nvidia GeForce GTS 450 1GB
Gainward GTX 560 Ti 2GB Phantom
Nvidia GeForce GTX 550 Ti 1GB (custom cooler)
AMD Radeon HD 5870 1GB
Nvidia GeForce GTX 460 1GB (custom cooler)
Gainward GeForce GTX 560 Ti Golden Sample (custom cooler and PCB)
AMD Radeon HD 6790 1GB
Asus Matrix GTX580 Platinum
Nvidia GeForce GTX 560 Ti 1GB (custom cooler)
AMD Radeon HD 6850 1GB
Nvidia GeForce GTX 570 1.3GB
AMD Radeon HD 6950 2GB
Nvidia GeForce GTX 480 1.5GB (custom cooler)
Nvidia GeForce GTX 470 1.3GB
Nvidia GeForce GTX 580 1.5GB
PNY XLR8 Liquid Cooled GTX 580 OC 1.5GB
Nvidia GeForce GTX 590 3GB
AMD Radeon HD 6990 4GB (stock)
AMD Radeon HD 6970 2GB
AMD Radeon HD 5970 2GB
AMD Radeon HD 6990 4GB (overclocked)
128
134
134
135
137
137
137
137
137
138
139
139
139
139
140
141
143
143
144
145
148
151
152
152
156
156
157
167
179
System Power consumption in Watts
Nvidia GeForce GTX 260-216 896MB
AMD Radeon HD 4870 1GB (custom cooler)
202
221
226
228
232
237
239
242
243
254
256
270
270
272
272
292
292
298
302
316
322
324
330
339
347
357
384
417
463
491
*Note*
The Radeon HD 5970 2GB was unable to complete a run of the Unigine Heaven benchmark, and as such is ranked with a zero for load.
Thermal Performance
Gainward GeForce GTX 560 Ti Golden Sample (custom cooler)
4
7
9
10
10
10
10
11
11
11
13
14
14
15
15
15
16
17
18
18
18
18
20
21
21
21
21
24
Delta T in °C
25
30
34
35
36
37
38
39
41
41
43
45
46
48
51
51
51
53
54
55
59
59
59
60
62
63
67
Delta T in °C
*Note*
The HD 5970 2GB was unable to complete a run of the Unigine Heaven benchmark, and as such is ranked with a zero for load.
Read our
Performance Analysis.
